<SPAN class=postbody>1. If I have a laptop with only one external bay for Floppy/CD-Rom and my laptop won't hotswap them, even though they both work, what is the problem? Is it my APM needs to be enable in the BIOS or do i always have to restart to swap them?
2. If you can format a floppy drive but the system won't allow you to format a removable USB disk drive, what is most likely the problem? (both are working normally) Do I need to enable a group policy option?
3. If I want my user name and password to be stored automatically everytime I check my web-based email, what do I need to do? Enable 3rd party cookies, session cookies, or change some trusted site/security settings?
4. If i have a driver related to a docking station portable storage device that always fails to load whenever my laptop is not in its docking station, should I make two hardware profiles AND disable the storage device *or* remove it?
5. Does it matter if my PXE-compatible network adapter is in the 2nd PCI slot rather than the first, if its "Boot from Network" not showing up in the boot order list?</SPAN>
