I want to build a Linux FTP server at home. I will have a dedicated system just for the Linux. Yesterday, I was trying to install Mandrake on it, but I got into a point where I am confused. This is why I am here. I am hoping there will be people willing to help me. Thank you very much!
Here is my system spec:
AMD 300mhz
Voodoo 3 Video Card
160 RAM of PC100 SDRAM
ISA D-Link 10MBPS NIC
6 GIG Primary
17 GIG Secondary
CD-ROM DRIVE
Currently, I have no OS install on the system. I am planning to install Mandrake on it.
Question 1
I was reading some installation documentation on the net. It mentioned that Linux is not that great detecting plug 'n' play device and ISA device. The best thing I should do is to install Windows first, and copy down all the Hardware Resource setting before attempting installing Linux. Is that recommanded? If so, I probably will put Windows ME on it to get all the Hardware Resource setting. I would like to get some advice on this, thanks!
Question 2
This is reqarding with Partition. Should I use the default partition setting or I should create my own? Is there any advice on this? I also notice that if you choice default, Linux will create 3 partitions. What's the 3 partiiton for? Yesterday, after I cancel out from middle of installation. I tried to delete all the partition, because I want to start out fresh again, but I can't. So how to delete Linux partition? Can I use FDISK or I need a special utility?
Question 3
There's so many package in Mandrake, which one should I pick? I picked the FTP Server package, but when I click next, it said FTP server will runs automaticly. Should I accept that or I should set FTP up later after installation complete? I want to have control over the FTP server, so I can turn on and off whenever I want to, just like BulletProof FTP in Windows.
Recommandation and Advice will be great! Thanks for reading.
AMD 300mhz
Voodoo 3 Video Card
6 GIG Primary
17 GIG Secondary
CD-ROM DRIVE
Question 1
Question 2
Question 3
