questions regarding 650ti boost sli
abuzar
hello , recently i got some money to buy a graphic card so i was thinking of buying 2gtx 650ti boost and wil buy a new motherboard also because my motherboard does not support SLI , so can u suggest which is the best cheap sli lga1155 socket motherboard and all this worth it?
thanks.
current specs:
processor - intel core i5 2500k
motherbaord - intel dh67bl
ram - 4gb
monitor- lcd tv 32 inc 1080p
psu - cooler master thunder 500watt
cabinet- cooler master elite 371
hardisk - 500gb
TOTAL BUDGET - 400 dollars
the problem is i cant spend whole 400 $ all at once so if a buy a single card i will maximum can buy gtx660 ti thats why i thought to SLI
The GTX 650 Ti BOOST is a great card and, overclocked it matches a GTX 660. They are faster than a GTX 460 1GB. Just make sure you get the 2GB versions, OK?
