I need to put together a very fast PC for some serious number crunching. At the moment I'm considering a dual AMD cpu machine, with either AMD 64's or Opterons (1MB L2 cache). I assume these will give more bang for the buck than Intel's offerings. The case must be rackmount because we are running out of room for anything else. I will need about 2 - 4GB of RAM. Can any of you guys give me advice on:
- What's the difference between AMD 64's and Opteron's?
- What's the difference between socket 939 and 940?
- Are there any good motherboards out there that can handle dual AMD's?
- What is the benefits of ECC Registered memory over standard memory?
- What's the speed difference between ECC Registered memory and normal memory?
Thanks!
Thanks!
