OK, so I just got this new system. Athlon Blue Menaie 750 TBird@1050. Pretty sweet.
Stuck into a Fong Kai case. Case came with a 90mm exhaust fan and a 120mm intake fan, plus the PS fan.
The 120mm fan was LOUD. I mean REALLY loud. Sounds like a freaking plane taking off or something. So I ditched it and replaced it with the 80mm fan out of my old Dell.
So, here are my questions:
1. Someone said that bigger is better, since a large fan will spin slower to move the same amount of air, hence will be less noisy. That sounds great, but does ot actually work in practice? How do you get the 120mm fan to spin slower and quieter?
2. The 80mm fan I got from my Dell (JMC/DA-TECH, 12V, .15A brushless) is very quiet. Can hardly hear it. The 90mm fan (T&T, 12V .32A) is much, much louder. Why?
3. The 50mm fan on my Vantec HSF is the loudest fan in my system. High pitched, irritating noise. IS there something quieter out there? Should I consider replacing the entire HSF?
4. The entire system is just too damn noisy. Any suggestions for how to quiet it down without oosing too much cooling?
Jeff Heidman
