questions, please help :)
skateis2s
31
what type of cooling would you need to OC a 2.4 to 3.0, would standard would work?
and is housebrand memory just as good as kingston or whatever if its all the same specs, speed, voltage, latency, etc??? what makes other brands better or whatever? please help and thanks!
JustAnAverageGuy
9,057
first q: Normally the stock HS\F is sufficient.
second q: I would go with kingston over "housebrand" anyday, as house brand memories are often generic and may or may not run at their rated specs.
Corsair, Kingston, Mushkin, Crucial all make reputable memory.
