Questions for the Klinux Help Desk....
Viztech
My Klinux dualie P2-266 has been happily munching for 63 days now. What is the procedure for changing the ini on the fly, and manually flushing the client, since I made a booboo in the original configuration?
Seems like I did this once by starting another terminal session, logging on as root, cd to the dnet directory....yada, yada. I just forget the commands to get there. 😕
viz
Ctrl/Alt F2 to move you to a different terminal. Login. CD RC5. ./dnetc -flush to send the blocks on their way. ./dnetc -config if you want to configure the client, -shutdown if you want to stop it. After you're all done, type exit and hit enter. Then Ctrl/Alt F1 to go back to terminal one. Or, you could just run it from 2.
Russ, NCNE
Hey Thanx Russ. That is just what I was after 🙂
It even was able to keep the summary up to date. 30944 blocks done in 64 days!
viz
