Purchased an Hitachi USB 2TB SimpleDrive as it was on sale for only $139. It seems to run OK & I do need it for archive. Bunch of questions though:
1. A hidden file that cant be deleted called "System Volume Information" has showed up. Is this really needed? If not how can it be deleted with out formatting the drive?
2. The Recycle Bin folder shows as "Recycler" & contains an undeletable folder "S-1-5-21-1292428093-............... " What's going on?
3. - Chkdsk shows 4KB/allocation unit. Why so small? I specified 32KB for the 300GB Maxtors to assist large file transfer. Generally small clusters with a huge drive like this will need a gigantic allocation table.
4. Would WINXP OS actually be able to reformat this large drive to full capacity? (It looks like it would work.)
5. It comes with software on the HDD. On application is the Fabrik backup, but the other is a Turbo USB supposedly to increase the transfer speed. It does seem to need the Turbo USB. Does anyone have experience with this application from Hitachi (probably also something that Buffalo uses if I had to guess)? Im just concerned that this application, if it doesnt work well might mess with my USB drivers & would be an issue to repair.
Thanks in advance
Thanks in advance
