I am about to put together my first PC with the following components:
Antec SX830 case, 300w power supply
ABIT KT7a-Raid mobo
Duron 800(RETAIL)
256mb Industry Standard PC133 ram
Quantum Fireball Plus AS 40gig (ATA100, 7200 rpm)
HP 9150i cd-rw
ATI Rage Fury Pro (32 mb)
Guillemot Maxi Sound Muse sound card
I would eventually like to try overclocking this system, but my first priority is to get it running stable with no tweaking.
Here are some of my questions:
Should I scrape the thermal tape off the Duron/heatsink and use a thermal compound instead?
Should I try to connect bridges right away, even if I am not overclocking right away.
If I don't get them connected correctly the first time, will the CPU still work, just not be unlocked?
Pencil or conductive ink?
I was originally thinking that I wouldn't try to connect the bridges right away, but is it better to do it right away, before putting on the heatsink rather than taking the chip out later and removing the heatsink?
Any tips, tricks, advice, opinions, etc (don't be limited to the duron overclocking stuff)you can give me is greatly appreciated.
Thanks in advance,
Gary
ABIT KT7a-Raid mobo
Duron 800(RETAIL)
HP 9150i cd-rw
Thanks in advance,
Gary
