I'm looking to buy two 120mm Yate Loon fans from jabtech but I have just a few questions:
1. Should I go with 20mm or 25mm thick fans? 20mm seems to be 8dB quieter than the 25mm but $1.50 more. Are the 25mm more durable?
2. How do I undervolt these fans? If I go with the low speed D12SLs and undervolt will they even be worth it? I remember reading something about undervolting will sometimes cause a fan not to spin at all because not enough power is supplied.
3. Are closed corner fans the norm?
4. PWM, does it only work with the 4pin connectors on the motherboard? How about 3pin connectors?
