I am building a new computer, and plan on using the Thermalright ULTRA-120 Extreme heatsink to cool my CPU. However, I am unsure of whether or not it will fit. Given the following motherboard, CPU, and case, would anyone be able to tell me if it should fit fine?
Specifically I am buying:
AMD Phenom 9600 (the heatsink is compatible with the AM2, should it also be compatible with AM2+?)
Gigabyte MA790FX-DS5 (will the heatpipes on the motherboard get in the way of the heatsink?)
ECA5000 Uber Chakra (I bought the version with the 25cm fan on the side, will the heatsink be too and thus be blocked by the fan?)
Thank you in advance for your help 🙂
