Originally posted by: Kayotic1
He reformatted and I'd like to get him my songs again using an ftp site. My only problem is I don't know where to find a host address to support my ftp site. Any suggestions on where I can find a host?
If you're hosting an FTP server, he just needs some way to find you. Host address could be a URL, or it could be an IP Address, etc. I don't have any experience with WS_FTP; I've used the FileZilla FTP server without any issues before.
1) Register with a service such as dyndns.org. You'll probably have to install a small piece of software which will update the dyndns servers with your ip address as it changes. This will allow your friend to reference your specific IP by name - say, kayotic1.dyndns.org. As your IP Address changes (you most likely have a dynamic address), the little client you downloaded will inform dyndns appropriately.
2) Install your FTP software. If it's requesting a host name at installation, provide it with the address you obtained in step 1.
3) Setup the software - create users, and point it towards the directory you wish to share.
4) Check your port forwarding. You'll probably have to investigate your specific brand of router. You'll also need to do this for the local firewall, if you have one installed.
At that point, it should be easy for your friend to use FTP Client software (such as is built in to IE, FF, or something like filezilla). He'd be provided with a) your address (*.dyndns.org), b) a user name, and c) a password.
As mentioned previously, your ISP might block the default FTP port. In that case, you'll need to modify your server software and supply your friend with the new port.
