So I did search the forums and found threads where people listed their benchmark scores for 3dmark01. I noticed people don't ever list what settings they used when running the benchmarks. I built my 1st PC and just want to make sure everything is good so I am testing the video card using 3dmark01.
What settings should I use and should I loop the tests? Also, would you recommend I use the 03 or 05 versions of the benchmark? I just wanna make sure my video card is good so I can return it if not.
Finally, I ran 3dmark01 this morning but when I came back it had stopped cause it said the window had lost focus. So I ran it again a while ago but as soon as the first test started WinXP rebooted and started again and said there was a "serious error." This concerns me. I just tried to run the benchmarks again and they are running so not sure if I should be concerned about this "one time" error.
thx
thx
