Questions about radiators... (water-cooling use)
MrHelpful
Banned
Apr 16, 2001
2,712
Has anybody ever tried to run them in parallel or in series? If both, which way runs cooler?
lastig21
2,145
I have not personally run 2 radiators. If you share a reservoir though, I doubt it would make much a difference.
ST4RCUTTER
2,841
It will make a difference, but you'll need a pump with a little more head. Overclockers did a good article on the thermal properties of radiators, flow rate etc. Basically it's best to have a high flow rate through the water block, and a slow flow rate through the radiators. This usually means tying the output of the pump directly to the input of the block. By the time the water gets to the radiators, it should be feeling the "drag" of all those turns. Two radiators should just slow it down even more (which is a good thing). From what I've read, having them in parallel is better than in series but I could be wrong on that point.
Jen
24,206
14
for myself i feel a single radiator bigger the better is best overall. less hassle with all the lines and pump
Jen
