- May 29, 2012
- 158
- 7
- 91
Hi guys.
First time posting in AnandTech forums. (But a long time reader).
My setup.
3770K
AsRock Fatality Z77 Professional
4 x G.SKILL ARES 2133MHz (16GB)
I've found a stable overclock for 3770K @ 4.5GHz
Offset = +0.050V
Load-line calibration = Auto (Level 5 which is the lowest/mildest)
All power management options are at default (enabled) (C1E, C3/C6 etc)
Under Prime95 and LinX load, CPU-Z reports 1.200V
This passed 20 passes of LinX and 10 hours of Prime95 (Temps ~ 93C under full load)
I have two questions for those overclocking 3770K.
Now, my questions are :
1. Is it better to *raise* load-line calibration and *lower* offset voltage ?
For example : Offset = +0.040V with LLC at Level 2 ?
Not sure if this would make difference at all since my 3770K seems to require 1.200V under full load to be stable @ 4.5GHz. (Be it with LLC or not, as long as 1.200V is provided to the 3770K, it's the same, right ?)
2. When I went with *Fixed* Mode (rather than *Offset* Mode), below were the value/settings in BIOS which gave 1.200V under full load (according to CPU-Z).
Fixed = 1.215V (BIOS)
Load-line calibration = Level 2 (BIOS)
Under idle as well as Prime95 and LinX load, CPU-Z reports 1.200V
And this gave me BSOD in Prime95 load.
The same voltage was applied to the 3770K. (Offset Mode and Fixed Mode) Why would Fixed mode give me BSOD while Offset Mode goes stable ? (After all, the same amount of juice is provided to the CPU (1.200V)).
Thanks!
My setup.
3770K
Offset = +0.050V
Thanks!
