where can i get a good multi card reader for cheap (sd mspro etc...) ? (less than $20 a little higher is acceptable) and also where do i plug in this card reader ?
i bought mine at fry's, and i've got an internal usb one that takes a floppy slot. they also have a version that has the multi-card as well as a floppy all jammed into that same spot. dont remember the name but it's all generic anyways.
thanks guys, i have another question, i see that SD cards have different speeds like 60x, 133x, 150x..etc...does it depend on the card reader how fast you can read/write the card? or is it just the carD?
i'm pretty sure that it's the card that determines the transfer speed. these readers are so cheap to make anyways, there's no point in making anything except that fastest interface.
