Questions about GeForce 4 MX420
bswail123
87
I actually just bought a VisionTek XTASY GeForce 4 MX420 for $99 at CompUSA and was wonderingif I should take it back and get a better card? I am currently running a PIII 800/133 - 256MB - 32MB TNT2 (not even Ultra) so this card is truely an upgrade. But my buddy said that this G4 MX420 was a crappy card and I should just bite it and spend the extra money on a G4 Ti 4200. I am not really a hardcore gamer at all, just wanted a video card update. What are you opinions on this?
Athlon4all
5,416
The GF4 Ti 4200 will be limited by ther CPU. But then again, the MX420 is at best 15% faster than a GF2MX. The fastest you will likely get fpr your configurtion is a MX460/MX440 cause they are based on the GF2 architechure which does better on older systems.
EDIT: Just thought I'd add, why'd u get a new vid card if u aren't a gamer? 2D IQ/Performance? if you aren'ta gamer then I'd suggest getting a Radeon 7500 over the GF4Mx's cause they are more well rounded cards although they are slower than the MX440 and 460.
Booster
4,380
I second that. Either get a Radeon 7500 to get a better 2D and video features or just stay with your older card b/c the 440 woudn't improve anything for you.
ChiefClancyWiggum
Scratch the MX420, it's pretty crappy. Don't get a Geforce4 4200 either, it's overkill with your system. I would go for a radeon 8500 which goes for around 100 bucks online. But if you want nvidida get the mx440, which is dirt cheap online, around $70-$90.
bswail123
87
well I got the card for a few reasons, first I did buy one new game, GTA3 and it crawls even at the lowest setting, but I also really liked the SVideo output at 1024x768 available on the MX420. Does the Radeon have a Svideo out? I am also adding a DVD-ROM to my machine and watching my movies on my PC and figured NVIDIA was the way to go. Never really been a big fan of ATI.
Ionizer86
5,292
MX420 = small redo of MX400 (very old technology) Basically, they added a new memory controller into the Geforce2 MX, and they left the memory bandwidth the same. For the $, a R8500LE is much much faster. Even a Geforce 2 GTS will be faster!
bswail123
87
well i went back and returned the MX420 and picked up a Retail ATI Radeon 8500LE 128MB DDR card. Just wondering if anyone knows anything about a card bios flash that enables features from the regular Radeon 8500??? Just heard someone say something about that awhile back. Thanks for all your help guys
ElFenix
102,393
8,552
radeon 8500 is $97 at newegg. return the overpriced crapUSA crap.
the GF"4"MX is really just a GF2MX with a better memory controller. its not as good as the one on the GF3 series, though. they also gave it quite a bit more mem bandwidth than the GF2MX was ever allowed. that doesn't mean it isn't outperformed by a GF3Ti200.
