- Oct 18, 2000
- 23
- 0
- 0
I'm not yet overclocking my system, but it appears to be running hotter than most other people posting. The Bios reports 117°F, Sandra reports 113°F, and VIA Hardware Manager is reporting 118°F. My processor was a boxed unit from AMD with heat sink and fan, so I have no idea what brand the fan really is. I'm not doing any cpu intensive applications at the moment either.
Will a less than optimal power supply cause the processor to run hotter? My power supply is a 250w unit that came in my InWin A500 that I was using with my old socket 7 board.
Also, the heat sink has a thermal tape that contacts the processor. I followed the instructions and peeled the blue plastic off the thermal tape before the heat sink and fan were installed. Would it be better to remove the tape and use silicon thermal grease?
