- Jul 2, 2004
- 4,890
- 1
- 0
So, I just built my rig last week and I've been putting it through it's paces.
My rig:
Athlon 64 3000+
Radeon 9800 Pro
MSI K8N Neo Platinum mobo
Nu Tech DDW-082
Samsung 160GB HDD
400 watt Sparkle PSU
Kingwin KT-424-BK case.
I just have some questions...
Idle cpu temp is 43 celcius (36-37 w/ CnQ enabled and idling), case is 43-45 celcius.
Load cpu temp is 57 celcius and the case gets to 48 celcius.
Atleast that's what MBM says, the BIOS says the same also.
Currently there's 3 fans in the case.. two in the front for intake and one in the rear as exhaust. They are the ones that came with the case. The CPU cooling is stock.
I have two questions..
1) Should I be worried about my temps? I've noticed a few times while gaming that I get artifacts, is this because it's too hot?
2) Would putting in my 300 watt Antec PSU from my old pc be enough to power this rig? I'm guessing it might be, since I only have one optical drive and one hdd.
I've noticed when I first booted up, that there was a lot of heat coming from the PSU, but everything else was cool. Every so often I check it, and it's the same thing, the PSU seems to generate the most heat.. could this be because it only has one fan on it?
Anyways, any suggestions would be appreciated.
Oh, and I'm in South Florida.. if it means anything.
Thanks.
My rig:
Athlon 64 3000+
Radeon 9800 Pro
Nu Tech DDW-082
Samsung 160GB HDD
Thanks.
