*<* Questions About Cooling Setup *>*
BChico
2,742
Ok i am using a Piii 1.0ghz @ 1.2ghz, 1.85 volt, temps are good, 80 idle and 100 full load, this is using a pal6035 and delta monster, this sucker is loud!!! What is the next step down from this loudness wise, without loosing all my perfromance, or should i stay with it? Also i just have crappy 80mm case fans 4 of em, that came with my sx1030b case, i was looking at the new sunon high performance 80mm are they the best??? Last question delta at 46dBa, will i hear 4x34 dBa case fans over top of that or will i just here the delta, if i went to all fans that were 35 or so dBa would i only hear 35 dBa or do you have to add the dBa's together?
Challenger
3,044
51
I've got an sx830 case with three 80mm fans PIII 700@ 1022 with Alpha pal 6035 with YS Tech fan my temps are 84 idle and 102 max full load.The YS is alot quieter than the Delta black lable(can you say huricane).If I was you I'd go with YS Tech!:cool:
