Questions about APC UPS products
jagr10
I heard they are good and i am looking into one in case of a power outage. Now i know nothing about these things. Do you plug every electronic into it or just the computer and monitor? Which one is the best for home use?
HOw does the battery thing work? Do you just change the batteries every so often or do you need special batteries that cost a fortune?
THanks.
Most home APC products (entry level) have two or three plugs that are battery powered. Most commonly you want to only plug in the pc and monitor.
Yes, the APC's are good, but some APC's are better than others - particularly the software that comes with them.
Basically, you'll want to plug anything that is important to stay alive during a power failure. Don't plug a printer in though, particularly a laser printer, as they have large startup surges that can kill your UPS. Most likely, you'd want your computer, monitor, and maybe cable modem/etc. if internet access is important during a power fail.
Most of the mid-level and higher UPS's will have one or more battery backed-up outlets, and one or more surge protected outlets. You can use the surge protected outlets to protect other components such as your printer, but no power is provided when the power fails.
The batteries should last at least a couple of years. I had a cheap UPS die after about 2 years, I've had others that are going on 3+ years now. If you overload it, the batteries will die sooner.
As far as which is best....tough question. A lot may depend on whatever goes on sale next. I just picked up an APC 500 a few months ago for about $20 AR at Staples, and it's very nice. Good software (i.e. allows me to turn the beeping off); I'm using it on my TV/Satellite right now. The batteries can be changed - you'll have to search online or eBay for them - but the whole units go on sale regularly for $15-$25 AR which is the route I go.
BTW, I like the mid-level Belkins as well. The software seems nicer than some of the APCs have.
BTW, when I say mid-level, I mean for home users. You can spend thousands on a UPS if you want; I'm talking about the $75-$100 range.
APC home units with 3 surge protected outlets and 3 battery outlets, modem protection, and serial cable can be had for roughly $30-35 at Office Depot.
Thanks for your help guys! I knew nothing about these things before. Now i have something to go on. I'll check around for prices. Thanks again!
APC has great UPS products IMO. Go here for an idea about what size you want/need. They higher the rating, the longer your components will remain powered. If you just want a UPS so that your PC can shut itself down (via the included software) or so you can shut it down properly, you can get one cheaper. Check out that link, I found it very helpful when I bought my APC UPS.
\Dan
