Hi, I just built my pc and it came with 3 Superred 80X25 fans. I want to use a zalman speed controller (or any type of low cost speed controller) but the power connectors are the 4-pin molex connector. So I'm wondering if I can use the speed controller since there is no third wire for speed control?
I don't really want to do the 7v mod. Should I just replace the fans? I was thinking if I can't get the fans I have to work; getting 2 panaflow L1A fans but I can't find a good site that has them in stock. Newegg.com doesn't carry them and SVC.com is out of stock. Anyone know of a reputable site that sells the L1As?
Thanks for your help.
