Question to those that used a rear window defogger repair kit for unlocking an XP
Schwan
494
I'm trying to unlock my XP 1600 and bought a rear window defogger repair kit. I just need somebody to tell me what to use to connect
the bridges. It came with a brown paint in a little bottle, and some type of clear adhesive with glittery stuff in it. I'm thinking I use the
paint but just wanted to make sure before I do it. Thanks.
Detselom
183
LastRide
946
Read the package to see if you need to mix the 2 together.I bought some defogger stuff but it came with one bottle.Some stuff you have to mix 2 together.Fill the pits with super glue and when dry scrape it level.Tape off the dots first so you don't get any glue anywhere other than in the pits.Some people use finger nail polish to fill in the pits.Then connect the 5 L1 bridges with the defogger stuff.I used a microscope when drawing the lines and to make sure it was taped off good and the pits filled properly.It could be tough doing it by eye.
