Question to AIW Radeon Owners
dez032
72
Does your monitor need to be set at specific resolution to use the tv out? And if it does, what is the highest resolution it can be at to allow tv out? With the AIW radeon can the actions done on the tv be independent of the actions done on the monitor, for example, play a divx outputed to tv and surf the web on the monitor? I have an old AIW Pro Pci and had to be set at no higher than 800X600 in order to use the tv out. And with the AIW Pro Pci the tv output was only the exact copy of the monitor.
thank you
