- Jun 19, 2004
- 2
- 0
- 0
I was wondering if anyone has ever experienced a problem with an ASUS A7N8X-E Deluxe V2.0 Mobo setting the VCore voltage higher than the stock voltage?
I have a 2500+ Barton (unlocked) which usually runs a 1.64VDC stock VCore. All of the sudden the voltage is being set at 1.90 VDC. I tried to set it manually but I can't adjust the setting when I change the VCore selection to Menu. This increase in voltage is sending my CPU temperature skyrocketing to about 56C idle. At the current time I am not overclocking the chip or FSB.
Any suggestions? Thanks in advance for your thoughts.
wrhodesiii
wrhodesiii
