question regarding useing an LCD TV as a PC monitor
ViviTheMage
36,189
87
madgenius.com
Westinghouse sk-32h240s screen flicker issue--Its does great at 1366x768, but thats small, so I put it to the next up which is 1920x1080 and its huge, and perfect!
BUT things are a bit blurry/hazy. I also get a flicker too, I see it in WoW and CS...so its something with the TV, and I am not sure if I can change a setting in my graphics option, or on the TV set itself...thanks for any ideas!
Let me add I have an 8800GTS G92 512mb card, and the issue also happens with my M1330 at this resolution via HDMI - HDMI.
Dream Operator
344
From Amazon...
Technical Details
* Display Specification
* - Viewable Screen Size: 32" Diagonal
* - Aspect Ratio: 16:9
* - Native/Optimum Resolution: 1366 x 768
* - Color Capability: 16.7 Million colors
It should not be working at 1920x1080.
Same card here. 1080P DVI->HDMI. No issues.
ViviTheMage
36,189
87
madgenius.com
its a 1080i LCD TV though. I have my DVD player hooked up to it as well and it does 1080i fine via DVD player.
I know the 1366 is native, but it **should** be able to do 1920 fine.
VirtualLarry
56,572
10,207
Originally posted by: ViviTheMage
Originally posted by: JSt0rm01
it wont do 1x1 pixel mapping so you are losing information
so there is nothing I can do about it? Id be better off just going to the lower native resolution?
Yes.
I'm quite frankly suprised that it even displayed a 1920x1080 signal at all.
stepone
86
Your problem is occuring because your lcd is running at 1920*1080 & it's a 720p screen but capable of 1080i.
If you try to run the screen at 1080i res with a PC then your screen will refresh @30hz instead of the usual 60hz as it's running in interlaced mode which will result in screen flicker & refresh probs.
To confirm the refresh rate go to: Display in the control panel - settings tab - click on advanced - then the monitor tab & check your screens refresh rate.
For confirmation change the screen res back to 1366*768 & see if the refresh rate goes up.
ViviTheMage
36,189
87
madgenius.com
VGA only outputs 1366 lopri....as I stated earlier.
1366 gets me 60HZ, and 1920 gives my 60 hz, but if I get into the nvidia display settings it does indeed say its interlaced 60hz.I guess I am SOL, ill look for something else and return it.
Thanks all!
RamIt
777
186
VGA outputs 1080P (1920x1080) on my 1080p monitor but not in certain games for some reason.
stepone
86
There really are no shortcuts here i'm afraid. ie you want a 1920*1080 res from a lcd tv being used as a PC monitor then you're going to have to splash for a 1080p tv or just accept your current 1366*768 res...
postmortemIA
7,721
40
1080I is accepted as input and downsampled to 720P... supports doesn't meant it is showing it.
