so this would be what I'm looking for then?Originally posted by: Gunbuster
Looks like Optical
any recommendations? I'm not in a hurry so I don't need to go to a B&M store. Would RShack overcharge? any online store good? or will just finding the cheapest on ebay be fine?Originally posted by: thraxes
It's an optical TOS-Link connector... getting one is easy
Originally posted by: isekii
buy from ebay.
you can get an 6-9ft Acoustic Reasearch for under 10 bucks.
I use one of these to connect pc to home theater.
buy from ebay.
sounds good. Now I just need a s-video cable. any recommendations on those?
btw: there is a standard right? if a video card has tv-out then the same cable will work just the same as another card with tv-out?
found what I need. now just to find it cheaperOriginally posted by: isekii
Get it on ebay too.
Svideo cable is about the same price as optical cable.
I bought one of each on the same day.
I'm sure this guy has more. He sells both optical and svid. Make sure you browse all his auctions and pick out the one with the cheapest buy it now.
He also combines shipping so purchasing both with save you like 4-5 bucks.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14965&item=3084737774
