Does anyone know if the FPS2000 Digital Speakers can be hooked up digitaly to the Philips Edge using the "Proprietary Digital Din" that the speakers have or will this only work with a Soundblaster Live card?
the philips Accoustic Edge has S/PDIF cables and connections, and the manual has a section on connections for digital speakers. I have the card, but not the digital speakers, so I can't say I've done this from experience
Slurp- I saw that the Philips has the S/PDIF Connections, but Creative likes to use proprietary plugs that will only work with their soundcards/speakers. That's why I was wondering.
