Hi
I am looking at getting an NVMe SSD, however, reading my motherboard manual I am a little uncertain if the SSD will operate at the speeds its capable of
NVMe SSD: Samsung 970 Evo Plus 2TB
Motherboard: Gigabyte GA-AB350-Gaming 3
GPU is in the PCIEX16 Slot
Wifi card is in the PCIEX1_1 Slot
The SSD appears on the compatible list, however the manual has the below information which I am finding hard to digest... do the PCIe slots in use have any impact on the operation of the M.2 slot at a speed that makes the most of the SSD I am looking at?
In terms of the Samsung 970 Evo Plus 2TB - des anyone know how much space you actually have once formatted with Windows 10?
Motherboard info:
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280/22110 SATA and PCIe x4*/x2 SSD support)
* Actual support may vary by CPU.
1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_2 and PCIEX1_3 slots. The PCIEX4 slot operates at up to x2 mode when the PCIEX1_2/PCIEX1_3 slot is populated. The PCIEX4 slot operates at up to x4 mode when both of the PCIEX1_2 and PCIEX1_3 slots are empty.
1 x PCI Express x16 slot, running at x1 (PCIEX1_3)
2 x PCI Express x1 slots
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
Appreciate any help!
Motherboard info:
