Hi folks,
I just ordered the parts for my first computer build. I ordered a retail Athlon 64 4200+ X2 processor because it was the lowest price I could find, and I don't mind the 3 year retail warranty vs. the 90 day OEM warranty! Motherboard is a Gigabyte GA-K8N Ultra 9, and I am going to use a Zalman CNPS7000B HSF. This will require removing the plastic Gigabyte heatsink backplate and replacing it with the stronger one that comes with the Zalman HSF.
My question is (and I hope it's not comletely dopey): would it be a wise idea to install the processor with the retail fan initially (which does not require removing the motherboard backplate), and verify that everything is working, BEFORE I go ahead and install the Zalman HSF?
Or should I go straght ahead and install the Zalman HSF first?
TIA to all you experienced system builders out there!
Andreos
Andreos
