I just finished my first build, and everythings working great.
My first question:
How hot does a HD4850 normally get, mine is getting up to 56 C which isn't bad, the fan kicks up to medium speed at this point and cools it back down to 55 C.
The main question I had though is more of a general GPU question. The way the GPU sits in the case, the heat sink points downwards. This isn't as effective at cooling is it? Because heat rises. Also, most of the air flow is above the GPU around the CPU, meaning the air is probably pretty still around the GPU's heat sink.
The card wont overheat, the medium fan speed keeps it cool, but it's noisy. Any suggestions? Perhaps rigging up another fan with a couple zip ties could keep it from reaching that noisy fan speed?
Edit: I'll post a picture later, if needed.
My first question:
