Okay, my 650 k7 came with a heatsink and fan (slot a). I have a small 60mm fan blowing air on it, an 80mm fan on top of the case above the PSU (it's a full tower). I have an intake 80mm in the bottom front.
My computer gets pretty damn hot inside.. it's all scsi so i have scsi cables goin all the way up through the side so its a bit cluttered.. Awhile ago I got my bios alarm (assuming heat) so I turned off my PC and it was really freakin hot inside.. PSU was hot, case was hot.. cpu.. etc.. I think something went wrong (was playing UT..) becuase after some cooling and turning it back on it was like 63C in the BIOS.. my computer (according to MBM5) idles at 53C, and 56-58C under load (Unreal Tournament).
This is crap. Did I mention the PSU is blowing out really hot air (normal?). I'm kind of new with this.
ANYWAY.. I ordered the 80mm's from Outpost, they're antec's.. I have no idea what the specs are.. I don't kno what the 60mm is, I pulled it out of my old system (p200mmx).
So, I decided to order a GW VOS32 Heatsink/fan. I also ordered 3 Panaflo L1A since I hear the VOS32 is loud as it is and my scsi drives are full height cudas, so those are really loud too. I want to replace my intake and exhaust with the panaflow's and if possible, my psu fan with the 3rd, is that safe? What do you guys think?
Also, would it hinder the vos32 if I changed the fans to something quieter? Or I shold just leave those as is.. any suggestions welcome..
 Facebook
Facebook Twitter
Twitter
