Question re: PCI Express lane allocation on Asrock Extreme4-M.
TrueWisdom
277
Hey all:
I had a quick question for you re: the Asrock Extreme4-M mobo and how it handles its PCI-Express lanes. (You can find the board here: http://www.newegg.com/Product/Produc...82E16813157294)
Basically, for whatever reason, Asrock placed the front audio panel jack right next to the top PCI-Express x16 slot. According to newegg's reviews, most big cards crush any cable plugged into this port. I've got a Radeon HD 5870, which is a fairly big card (~11", large HSF), and it would probably exert some pressure on any cable plugged into that front panel jack. Furthermore, I frequently use the front audio ports, so I'm a bit worried that this issue will irk me to no end if I buy the board.
Hence my question: can I stick my card in the 2nd PCI-Express x16 slot, rather than the first, without running into strange and unfortunate consequences? It's been a while since I put together a rig (last custom build was an Athlon X2, to give you some context) and I know that boards then and prior did not enjoy it when you chose nonstandard slots.
Any help would be appreciated. Thanks!
nightspydk
339
19
As long as you do not attempt to run sli, the answer would be yes. It should be possible to run *16 of the second lane. Go to bios set primary vga. :)
afaik..
Just to elaborate. SLI might need the primary lane in short.
Insert_Nickname
4,971
1,696
The problem is that most boards secondary slot is only electrically capable of doing 8x in the secondary slot. Unfortunately. I don't know specifically how the Extreme4-M is wired, but I'm guessing this applies to it as well.
TrueWisdom
277
Thanks guys. I'll keep that in mind. I'm also looking at a Gigabyte Board (D3H) because I don't plan on using SLI anytime soon, and I may edge towards that. Asrock does seem to be the manufacturer of choice on the boards nowadays, though.
Kenmitch
8,505
2,250
As long as you throw a IB chip in it i think it will work fine anyways. HD 5870 isnt pci 3.0 anyways. Doesnt pci 3.0 double the bandwidth from pci 2.0 which should make it a wash.
