<P class=MsoBodyText style="MARGIN: 0in 0in 0pt">The 8K3a and 8K3a+ are touted as having the 1/5 PCI divider, as well as the listings in BIOS to show that with the 1/5 divider on and running the FSB at 166mhz, that the PCI buss is running at 33mhz, and that the AGP Buss is running at 66mhz.
<P class=MsoBodyText style="MARGIN: 0in 0in 0pt">If you take, for example, an AMD XP-2000 (1.66ghz), and unlock the multipliers on it, can you, then, simply set the multiplier to 10x, set the PCI divider at 1/5, and then run it at 166 FSB?
<P class=MsoBodyText style="MARGIN: 0in 0in 0pt">Everything should be in spec:
<P class=MsoBodyText style="MARGIN: 0in 0in 0pt">CPU (10 x 166mhz = 1.66ghz) / In Spec
PCI = 33mhz / In Spec
AGP = 66mhz / In Spec
<P class=MsoBodyText style="MARGIN: 0in 0in 0pt">Am I missing anything here?
