Question on water cooling
Cheekykid
1)If install my swiftech apex ultra water kit on a system and then unmount it for another system with bigger case what I should be becareful of?
I have already bought extra tube should it be needed. Can I still use the same water or if I unmount the whole kit the water gets wasted? Never done this before so i don't know
😕 If your using water who cares...
Now if your using fluid XP I can uderstand.
If it is fluid xp (or equivalent) it is still good to change that out after a while.
So it depends...
Well if you're just straight taking it off the system then the water should be fine; if it's a closed loop you might introduce some bubbles, but that's no biggy you'd just need to bleed it again. If you take the whole setup apart I would probably not save the liquid, unless light raincity said it's FluidXP or something expensive.
