Question on TV Tuner and video input ports
gaston55
I am customizing a Gateway system DX430X. You have the option of getting a tv tuner with it. If you do get the tuner, they say you also get front video ports on the tower. My question is, what are these ports used for and do they serve a different purpose from the firewire ports that are already on the front of the tower?
Their website say's the following...
Optional Front Video Ports
"Easily transfer video from camcorders and other devices with handy video input ports at the front of the PC, when upgraded to an optional TV tuner."
Thank you!
Paperdoc
2,464
358
"Video Input Ports" almost always means analog composite video signal inputs. These are the same as you have on a VCR, a TV and probably any DVD player. On VCR's etc they almost always are accompanied by two (for stereo) sound connectors - all RCA type plugs. Can't tell whether these also are part of the Gaetway option.
These are the base-level quality for video connections. Well, I suppose a cable TV signal has even lower picture quality. But other ways, like S-Video, Component Video, etc are better-quality analog signal connection systems.
Firewire, on the other hand, is a DIGITAL port, whether input or output. You can only send into your PC via this port a signal that is already digital. If your video camera has a firewire port, also, you are much better using it than using Composite Video. Besides, most video editing / capture software will do very handy things. You connect camera and PC via a Firewire port, and full-detail digital video and audio are transfered between the machines. Moreover, the PC's software can control both devices using the same connection, so it will start, stop, search your camera's files, etc. BUT if your camera does not have a Firewire port on it, you can't do this.
But suppose you have an old videotape you want to play on the VCR and capture on the PC. The straightforward way, IF you have the composite video port, is to hook up RCA patch cables from VCR Out to PC In, start the capture software, and then start the tape. Some digital cameras, however, offer another alternative (mine does). You can play the tape from the VCR into the camera instead, and its system for converting incoming analog signals to digital form for recording is always running. So it simply relays that digital info stream out the Firewire port, which you can connect to your PC. This MIGHT (depending on the quality of the video capture board vs the camera's converter chip) give you a better conversion to a digital file in the PC.
Finns14
1,731
Wow what a great answer
zig3695
1,240
to add, there is no consumer high-def inputs for pc's other then a couple high-end expensive HDMI in/out cards. firewire is the best there is really, and its onlyhalf as good as true 1080p. it will likely stay that way, but it is funny how you can record over-the-air HDTV movies and the result is MUCH better quality then DVD's! im sure someday HDTV in/out will be a regular feature of video cards though, itll just take time. years...
mercanucaribe
Banned
Oct 20, 2004
9,763
You won't be able to record though unless your hard drive, processor, eyeballs, and brain are HDCP compliant.
zig3695
1,240
apparently not if youre recording from OTA broadcasts from the major networks, abc, nbc, cbs and fox. ive always wondered this too, but i get full quality recordings and output with a dvi monitor and no HDCP in the video card at all. The copy protection doesnt apply here, there is supposed to be a 'red flag' data stream in the content to tell your pc to NOT record certain movies or sports they broadcast, but it either doesnt work or they just arent using it. i think the whole HDCP mess is mainly for movies bought on a disk...
