I have a 2003 mazdaspeed protege 215/45/17 size tires currently on them.
They are street tires and are horrible in the snow, so I'm looking to buy
some snow tires. I found some Blizzaks in the same size however, I'm
concerned with the performance difference with the low profile tire. Should
I buy 15" rims to go along with a set of winter tires? Or do you think just
getting the same tire size in the snow tire will be sufficient? Thanks.
