If I were to set up a new watercooling system, with blocks on my CPU, GPU, and chipset, which setup would be most efficient?
1) Running the water from block to block, from CPU, to GPU, to chipset, and finally to the radiator
2) Getting a 3-way splitter to run water to each block simultaneously, and then recombining the water flow before it hits the radiator
I realize the water flow in option 2 would be slower, but would this be better since the water wouldn't get heated incrementally as in step 1?
