I Impetux Junior Member Feb 24, 2004 16 0 0 Jun 30, 2004 #1 Is there any way to tell, other than looking at the box, if the Sapphire 9800 PRO you have is the 128 bit or the 256 bit memory interface? Is there anything on the board that would be indicitive of which one it is, or a detection utility?
P PrayForDeath Diamond Member Apr 12, 2004 3,478 1 76 Jun 30, 2004 #2 Maybe if you use ATItool or RivaTuner or some other tweaking utilities you can find out which version you got, I am not sure though
LTC8K6 Lifer Mar 10, 2004 28,520 1,576 126 Jun 30, 2004 #3 Any decent benchmark should let you know pretty quick as well as those utilities.
I Impetux Junior Member Feb 24, 2004 16 0 0 Jun 30, 2004 #4 I'm pulling in around 5800-6000 in 3Dmark03, which tends to make me think the version I yanked was the 256 bit model. Rest of the system for reference: 2.8 ghz P4 w/512 PC3200
