santuitman
Hello All
I just got an older motherboard for a side project. When I got it I noticed it has some burst caps. It posts ok but I want to replace the caps before I put it all together. I believe I can use a higher voltage than the original cap but how about the uF rating? Can that value be higher also? It calls for 10v 1500uF and I have some 16v 2200uF.
Any thoghts would be great
Thanks
Brian
Thanks
Brian
