Question on power supply part
tenest
177
wasnt sure where else in anandtech to post this question...
on (at least) the last three power supplies, i've noticed an "extra" connection but i can not for the life of me figure out what it is for. it's a 3 wire connection that ends in a plug that would typically fit into a fan header on the motherboard. i cant find my multimeter so i cant check to see what kind of voltages are coming from each of the three wires. i have seen this is exact same connection on an antec, enermax and powermax (oem) brand power supplies.
anyone have a clue as to what this for?
oh yeah, all the power supplies i've seen this on are P4/AMD XP capable.
bozo1
6,364
It is to plug into a mobo fan header. Some Enermaxes use that to power and monitor the 2nd fan. Some supplies with only one fan use it so you can monitor them as well.
