phillyman36
I am thinking about getting the Thermalright Xp-90c for my X2-3800. On their website they suggest this fan
Maker: Panaflo (Panasonic)
Model: FBL09A12M
Size: 92 x 92 x 25 (mm)
Bearing: Hydro Wave
Voltage: 12V
Speed: 2450 rpm
Air Flow: 48 CFM
Noise Level: 30.0 dBA
Weight: 110g (3.88 oz)
I cant find that exact model number but one similiar to it on newegg.
For those who have it i have a couple of questions
1) Which fan to get
2) Is it much better than the stock fan that comes with it( what are average temp with the stock fan and ave temp with the Xp-90c) basically how many degrees will i save by getting it
my motherboard will either be a Asus Sli deluxe or the new ASrocks agp/pci board
Model: FBL09A12M
Bearing: Hydro Wave
Voltage: 12V
Speed: 2450 rpm
Air Flow: 48 CFM
1) Which fan to get
