I asked on another topic about a pocket hard drive and someone suggested making my own. Ok, but what will I need to do to make it? What advice can you give on where to go and what to do?
I have decided on the 3.5 drive. One reason I can get over twice as much for a cheaper price. I found an ata160gb for 89 with a 50dollar rebate. That's cheap. This will be a little larger but not that much. Are there any brands of enclosures that would be recommended and why? Thanks again.
