Question on LCD TVs and using coax cable
Carl Uman
6,008
Hi,
My wife would like an LCD for the TV in the kitch. My question is that it seems most of the small units do not accept a cable connection. Am I missing something? My satalite box is to far from the TV to run RCA, S-video or anything other than standard coax cable.
This page is confusing. It says under features "RCA, S-video and component video connections, PC VGA (640x480) and audio connections" and under specs it says "TV/cable, composite (RCA), component YPbPr, S-video". So I'm not sure if it will allow a cable connector or not.
http://www.viewsonic.com/produ.../lcdtv/n2000/#features
Also I'm interested in the Planar 15" but wasn't sure if it accepted cable.
http://www.planar.com/products...v-pc/15_inch_LCD_.html
From what I can tell I need to be looking for ones with a tuner build-in or am I way off?
I wish they would also show the connectors then there would be question.
Thanks for any help since I'm new to this LCD TV stuff.
Carl
Matthias99
8,808
Originally posted by: Carl Uman
Hi,
Carl
You need a built-in tuner to use cable, as well as a coax input attached to said tuner. I would imagine most "LCD TV" units have one, but most computer LCD monitors would not.
That Viewsonic *seems* to have a tuner built in. link to comparative specs chart
The Planar lists an "Antenna" input, which is almost certainly a coax input connected to the tuner.
Carl Uman
6,008
Thanks
From some reason I missed a link on the Planar site and looked in the manual. Guess what. It has a tuner built in :eek: I seen the Viewsonic product guide but didn't look because the product guide stuff is usually junk :(
Well, thanks much for the help
Carl
