Question on IWILL XP333 and AOL
AMDYEHBABY
ok i bought the iwillxp333 yesterday and it was version 1 is that bad or should i exchange it or wat??? and isnt it supposed to have 2 audio connectors for the cdroms???
and why cant i log in to the site through aol(but it will let me view all of the stuff i just cant log in to it)??? i can do it through netzero though,it also does that with my friends fxp site too (yes ive tried the security feature,offers no help)
thanks to you guys in advance
(in case i use up my hours on netzero and cant log in)
flippinfleck
1,090
Ok, one question at a time.
<< ok i bought the iwillxp333 yesterday and it was version 1 is that bad or should i exchange it or wat??? and isnt it supposed to have 2 audio connectors for the cdroms??? >>
Well, is the board not working properly? Is there something that makes you think the board is defective? Most mobo's that have onboard audio do in fact have more than one connection for a cdrom but they may not be labeled as such.
<< and why cant i log in to the site through aol(but it will let me view all of the stuff i just cant log in to it)??? i can do it through netzero though,it also does that with my friends fxp site too (yes ive tried the security feature,offers no help) >>
That's something that Anand and the mod's decided a long time ago, in a galaxy far far away. Aol IP's have been banned from the forums, which is why you can log in via NetZero. Get a real ISP, some can be had for cheaper than AOL anyways. Any further questions about AOL and ATForums should be directed at Forum Issues, do a search first though.
MrBumpy
64
<< ok i bought the iwillxp333 yesterday and it was version 1 is that bad or should i exchange it or wat??? >>
The only difference between the version 1 board and the version 2.1 board (non-raid) is the vcore adjustment and layout. On the version 1 board, it can go up to 1.8 volts. On the 2.1, there is a modifier to let it go to 2.0 volts. Also on the 2.1 board, the arrangement of some of the capacitors is a little different, if I recall. This was changed to accomodate the use of larger heatsink/fan combos.
