Question on CPU frequency and memory speed.
algae
916
I'm running a A7V8X Deluxe and Barton 2500+. I have 1 G of OCZ PC3200 Dual Channel Ram running at 200 MHZ. Should I have the CPU frequency also set to 200 Mhz or leave it at 166 Mhz where it now is?
Tia for any info.
Gary
Le Québécois
560
If you want to overclock it yes, if you want the stock speed no..
I have the same config you have...if you decide to overclock, let me know plz whats the result. PM me.
Regs
16,665
21
Doesn't hurt any to have the memory a little out of sync with the cpu internal clock, however there will be no performance gain on a AMD set up. I have my memory set up to default to the cpu internal clock in the bios.
