- Oct 9, 1999
- 6,163
- 514
- 126
Ok, after looking at the Striker Extreme and P5N32-E SLI, I thought of a possible problem with their NB cooling solution and different computer case installations. Specifically, how well does this work if the motherboard is inverted in a case like many of the Lian Li cases and others?
The issue I see is that the NB itself will be "higher" then the heatsink fins that is meant to cool the heatpipe. From the pictures I do see that there looks like a bit of heatpipe that goes out part of the NB and then bends towards the PCI-E slots, but I can't tell exactly. Does it bend back up away from the motherboard and then back towards the CPU socket and then through the heat sink fins? If it does, it might still cause the heat pipe material to be able to wick away the heat and move it to the heatsinks even if the board is inverted...
I hope the guys doing the review at Anandtech test this out.
Edit... actually, now that I look at it more, that piece of heatpipe is actually going to the south bridge. I don't think this solution will work at all the more I look. Can someone verify?
