Question on 360/Netflix/Wireless
Fingolfin269
17,948
34
I managed to snag an Arcade at one of the circuit city liquidation sales so I can now move my ancient non-hdmi 360 to the bedroom. I only have one wireless adapter so I'm thinking of converting my WRT54G for use on the old one in the bedroom and going out to buy a new router for streaming HD.
First, what router would you suggest? This WRT54G has been a great device over the last few years and I really hope to find one with the same flexibility but faster transfer rates.
Second, I believe the 360 wireless adapter will accept the higher 'N' speeds. Can someone confirm? The reason I want the higher speeds is that this service has a bad habit of suddenly wanting to drop to some god awful res from HD if there is any kind of transfer hiccup.
Third, unrelated to networking, will I be able to log in to my 360 account from both 360s (not at the same time) and access the Netflix streaming functionality from both locations? I would NOT be logged into both at the same time. Only one HD so I would be moving it from box to box as needed.
Queasy
Moderator<br>Console Gaming
Aug 24, 2001
31,796
The wireless adapter supports A, G, and B. There isn't an official 360 adapter that supports N yet.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
If you're moving the hard drives from console to console then you should be fine with the profile switching.
MrChad
13,507
I have a WRT54G with DD-WRT firmware installed and it works great as a wireless bridge. YMMV always with wireless routers, but I can stream HD just fine over my 802.11g connection with WPA2 encryption enabled.
My understanding is that you'll need to get a memory card and store your Live profile on that card. Just move the card to the Xbox where you'll be signing in and you'll have no trouble switching between consoles.
LordGestle
764
^Correct. I have 2 xbox 360s and use the memory card to login to either system when I require Xbox live. The alternative would be to recover the profile on each console, takes several minutes, when you switch machines or to transfer the hard drive.
I aslo use WRT54G with DDWRT in the same configuration and get full bars on netflix streaming, including HD.
