- May 3, 2002
- 191
- 0
- 0
I was wondering if anyone here has had experience with Re-Edge Kits that you use to fix blown speakers. I have two tower speakers that each contain a tweeter, midrange, and woofer. Both woofers still work but the foam that conects the cone to the outside of the speaker is falling apart. I saw that re-edge kits exist but I am not sure if they really work. A few sites that repair speakrs say that you can't do it yourself with those kits and only experts should do it....Then again maybe they just want my $ so they don't want me to do it myself. Eitherway, before I try do it myself I want to know if these things work. It seems simple enough that it would work perfect.....Chris
Linky Winky
Linky Winky
