Question of 80mm Fans? with Antec SX830.. help!
LordChaos
11
Hi,
Im ready too buy Antec SX830 case, which you can put two extra fans
in front.. they come with two Antec 80mm @ 34.4CFm
im wondering if i should get H.P. fans in front like AddA 80mm @50cfm or Sunon 80mm @ 42.5cfm so they can pull air in fast
or Antec fans pulling air in and AddA/Sunon pulling heat out fast?
also are AddA Fans good?
Any Ideas or Advize.. would be great!
Thx!
Valvoline6
742
Let me add one more question if you happen to have this case. Do both of the included fans have 4 pin connectors?
fake
LordChaos .. get the most powerful you can without going into a level of unbearable noise. I recommend gauging your sound tolerance with the included fans and then making your decision.
Valvoline .. I have an SX1030 and both fans have 4 pin connectors, but I'm almost certain the same goes for the SX830.
LordChaos
11
Valvoine6
Yes, SX830 case/w 2 Fans do come with 4pins(Anetc80mmFans...
That went Q went over my head!
DOH!!
